A Quick Question For U!!! HELP!!!!
Guest scoobydoov3
Guest scoobydoov3
yeah hard it all looks normal to me...but when idling high..all i do is pull the right one to the front and it idles normal again. its weird. all that from removing a top mount lol..
any idea what it could be?? i will post up a pic mayb tomorow..i needa find the iacv..im sure i know what it is.
It may be the butterfly (is that what you call it) inside the throttle body sticking. You may need to get the IC off again, and spray CRC all through it.. and over those two throttle cable levers.
I had a slightly sticky accelerator pedal and didn't notice anything overly sticky in the throttle cable so didn't really do anything about it. Then I had the IC off one day and found it was the thing inside it was a bit sticky. Cleaned that up and was good ever since.
Guest scoobydoov3
ooo another scoobydoo hahaha.....so wat u sayin is to remove the top mount again and spray crc into the top mount????
Guest scoobydoov3
haha i FIXED the problem!!!! YAY YEAH!!!!!!! THanks alot everyone for all the help tho...what a funny story! During the process of getting vacuum line onto external..i accidentaly knocked off a vaccum hose on the drivers lights section and it had a funny pointy tee piece on the other end...quite trippy.
anyhow.... is the pic below the iacv???
