White smoke and tapping?
aim
Mate just went and looked at a 2000 B4 today for me and said as soon as it started, lots of white smoke billowed out of the exhaust, like, the size of the car kind of cloud. Also said there was a tapping coming from the engine... What could cause this?
The description says blown turbo, but I'm afraid there might be more too it? I thought white smoke was coolant which may mean gaskets?
First thing that springs to mind when i hear the word tapping is big end bearings. The tapping could be indicative of big end bearing, and this is always a possibility with the manual B4's (manuals have the 206kw EJ208). But big ends will be a deep "toc toc toc" from the middle of the engine, and not a head. So you can rule that out for now i suppose.
The smoke though can easily be causes by the blown turbo. Maybe the turbo is just utterly bumf*cked and making noise? Can also explain the loss of power.
 boostin said:
The crank and rods are the same. The difference is in the pistons and heads.
wouldn't changing the heads and pistons change the position of displacement rather than the actual displacement?
EDIT, blonde moment, moving the 'stroke' closer to the heads would increase the ratio and decrease it if moved further away... sorry :P
Guest boostin
 DPI']
[quote name='boostin said:
If there's more volume in the piston and head then it lowers the comp ratio.
And increases the displacement?
Huh??
I mean more volume in the piston crown, as in more dish, not a bigger piston....
Guest boostin
 aim said:
You could only increase/decrease displacement by modifying the crank... not the piston...
A larger diameter piston will increase displacement....
