Legacy not starting
Ryan
I've just done a engine transplant into my RS-B 1996 with a engine from a 1994 RS (both are twin turbo). Everything's swapped over sweet, using the donor engines manifold etc, just dropped the whole thing in. Turns over sweet but doesn't fire or start (intercooler is off but should still start for a few seconds).
Nothing on the donor engine has been unplugged from the block etc, just engine to body wires, so crank and cam sensors are plugged in. Theres a strong smell of fuel after cranking over. Ideas?
did you use the 94 engine harness? if so, swap it over for the original as commonly they fark the pins up and the wires dont end up corresponding correctly at the plug near the battery etc.. good luck.
Ah so looms aren't the same then?
