Cowtipper2016
Help please! Knock issues detected with btssm
19 posts in this topic
So I discovered the wonderful world of btssm and am loving it so far ... however when I had reset my ecu I had noticed a couple knock issues detected ... done just over 1000km since the reset on mostly highway conditions as well as some spirited driving over the maungamuka gorge (the log data linked shows the 8ish minute long and fun drive) ... after reading the log and checking my LV I am abit worried as most of the knocks come on at 4500rpm ... now it appears the LV has knocked my ecu down a few notches in the way of power...
First off I am curious as to how this would happen on a bog stock 2006 JDM legacy gt spec b 6sp manual ...
From my understanding this year was the change over year for example my turbo is supposed to be a td04 (from what i have read) but is instead a vf45 ... also being stick max boost target is 14.5 however I'm getting spikes up to 17 in some cases but more commonly around 15.5 for longer than a second
Any help or suggestions are much appreciated
Thanks
Share this post
Link to post
Wouldn't be super concerned about the knock. Without a tune for the fuel we have in NZ it'll never be perfect. A degree here and there isn't major
You want to post up a LV snapshot from BTSSM
Share this post
Link to post
Learning view snapshot is key.
You will get some knock on nz fuel, normally you get a few events that the ecu learns around, pulling a small amount of timing here and there.
Share this post
Link to post
Not bad at all. About where i'd expect to see a little knock for a stock tune.
1 person likes this
Share this post
Link to post
that left hand side avcs is bloody slow. pull avcs banjo filters, possibly a sensor starting to poo the bed
1 person likes this
Share this post
Link to post
thanks ill check that tomorrow .. just to be sure when you say left you mean passenger side?
Share this post
Link to post
yeah, they normally reference from drivers seated position iirc
1 person likes this
Share this post
Link to post
sooo ... i did an oil change using good ol golf 10w-40 and stp oil additive which is essentially a zinc mix and make the oil stick to the walls abit better .. checked that banjo bolt which was one hell of a bugger to remove so i just unscrewed it to have a quick look before putting it back in .. when i was putting it in i punched a hole in the side of the filter .. thought stuff it ill just put it back in as i need the car running (its a daily for the misus) ... gave it a quiet run for abit till it warmed up then done a pull from 0 to speed cut .. results are below .. looking over them it didnt make much difference however i see the exhaust vvt on right bank is doing the same damn thing
New Btssm run sincee oil change 0 to speedcut
Thanks guys for your input
Share this post
Link to post
Dont add zinc to the oil its not a dirty old v8. Try a 5w30 full synthetic.
1 person likes this
Share this post
Link to post
I will try that on my next service in a couple weeks thanks @evowrx ... coincedently i have just finished building an 87 VL v8 wagon haha ... it's my weekend burn out machine
Share this post
Link to post
Not saying that will fix the issue but it may help.
Mangamuka not a bad drive. Guessing if youre local there worth noting theres only 95 which explains the knock count.
Share this post
Link to post
i was a local there haha .. its my home town so was just up there to visit family and friends .. but for an AWD the gorge is excellent for running through as it pushes every limit the car has .. I actually live in Atiamuri between Taupo and Rotorua where there is an excellent gull that has 98 .. of all the terrible reviews saying Gull is bad and to use the likes of BP or Mobil i dont understand why as is see BP/Mobil branded fuel tanks filling that service station up from time to time
Share this post
Link to post
Only reason people don't go for it is it's not a traditional 98 octane fuel, it's 91 or whatever with 10% ethanol to raise the octane rating up to 98.
Share this post
Link to post
19990225_1965235253502116_72587065944257
*update* ... 2500kms into a new oil change including resetting the ecu (via Btssm) this is what i got .. pretty happy with the results ... nothing has changed in the way i use fuel or where i buy it either
Share this post
Link to post
55 minutes ago, Andy_Mac said:
Looks good. When was the last ECU reset done?
at the time of the oil change .. so 2500ks ago ... considering that first one had 1000ks on it im picking the fuel i got up north was S***
1 person likes this
Share this post
Link to post
  • Similar Content
    • By benyu0926
      Can't seem to find any after market air intakes for JDM BP5s? Do Grimmspeed fit/work on JDM versions?
      Any recommendations would be awesome, thanks in advanced.
    • By Cowtipper2016
      Hey team!
      looking for a part number or better yet the actual name of this damn pipe!
      i have a 2006 jdm legacy spec b 6sp manual VF45 turbo EJ20Y
      looking for the pipe from the turbo outlet to the TMIC ... looks like mine has a leak and has crumpled down at the bottom
      Any help would be appreciated guys
    • Steve
      Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.
      Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
