CODE 66!!
nt_a_foz
  • Replies 65
Got a scan tool? I think that gives you a more specific code than 66. Like it will tell you roughly which bit of the TT system isnt working right.
No it doesn't. It would if it was a rev D though.
Lol, thats twin troubles for you.
I've got a copy of the CEL 66 diagnosis procedure at work, and I'll hopefully remember to take a copy tomorrow.
Guest itsgotgo
Simple cure for bradley "STOP PLAYING WITH LEGACYS THEY ARE JUNK!!!!!!" Sorry to the leggy lovers :D ;D
BBOD=EPIC FAIL!!!! ;)
 nt_a_foz said:
This is my first one and my only one its such a piece of **** design and a pain to diagnose problems....
But hey it was cheap....and cheap means $$$ which = good haha
If you don't go insane trying to fix it!!
 smurff']
afm dont have anything to do with code 66 i thought
-smurff
Its a twin fail. Anything is possible.
[quote name='nt_a_foz said:
so swapped afms...Still no change
its not boosting at all now..
Where as before it did it sometimes before it cut and CEL come on..
Need to go over and check all vac lines apart from that any other ideas??
Yeah, recheck all your lines and connections. It has to be something there.
Did you pull the vac/boost lines off the primary turbo?
Iv swapped BBOX with flatmates one and refitted my one and no change so not the plugs....
What will pulling vac lines off primary do man? Free boost it???
The weird thing is it was intermitent as like it would boost properly at least once then cut..Now not at all...
No, was wondering if you pulled it off when the engine came out. You might have put it back on the wrong way around.
