CODE 66!!
nt_a_foz
The chart says sequential turbo system..
We took legacy for a drive...
was going ok first few pulls it didnt seem like it was hitting secondary..
Then next pull it hit secondary and pulled hard as and check engine light flashed...
It then went out we cruised for ages got onto expressway and put foot down CEL come on .
Next pull when it hits 5k (Secondary point) its "Cuts" all of a sudden..
And its showing code 66
Anyideas??
  • Replies 65
its 2 do with 2ndry turbo..
went driving just before....
It went mint for the first couple of boosts since car had been off for a hour or so..
Pulled both on first and second turbo..
Then all of a sudden just cuts and CEL comes on..
Its weird cause some times it has no boost it seems on any turbos then other times itl boost secondary..
But as soon as it cuts with the CEL it wont boost and hits 5k and cuts...
Hmmm
 nt_a_foz said:
ECV????
Bypass as in exhaust valve???
theres a valve in the exhuast manifold that diverts the gasess from turbo 1 to turbo 2 when required - where i cant remember.
your 66 might also be bov leaking.
66 is the catch all for any TT boosting issues - have fun haha
 nt_a_foz said:
secondary bov didnt seem to be leaking when i did ryans test last night...
But yeah next job (tonight) is to check the valve in the exhaust.
We want videos of you sucking on BOV's next time!! ;D
Lol get a 50ml syringe from your local pharmacy. Makes testing all of the vacuum lines and actuators a shitload easier.
 keltik said:
Lol get a 50ml syringe from your local pharmacy. Makes testing all of the vacuum lines and actuators a ****load easier.
how do you you use it to test them?
-smurff
 boostcut said:
you use it to create a vacuum... rather than sucking a black hose off.
This honestly deserves a place in the "BEST CLUBSUB QUOTES" thread which i would make if i wasnt useless
So swapped secondary bov tonight and tested the secondary exhuast valve..
Then found that one of the plugs going into the black box had a broken pin coming from the intercooler so hence we thought we had the solution
BUT it still cuts at 5k.
So am going to swap the black box from flattys b4 see if its a stuffed solenoid or something...
mmm hand job.,.
k swapped mels box into my car lol...
Didnt do anything..
Still the same problem....
Munted as to what itl be...
It pulls hard for one pull then next pull wont hit secondary any boost and it hits around 5k and it cuts and CEL comes on
