Oil for air filter???
 scottiescottiescottie said:
Have just purchased an HKS foam air filter and after a clean I am told they need re oiling.
I figure oils are oils aye so for this application what is a good cheap oil that could do the trick well? ;D
Im also told that less oil is more with filters as any excess can clog flow sensors right?
Don't do it dude... Unless you have a spare AFM handy....
I've got a K&N pannel filter on mine, Only found out your not meant to have them after buying it and since it cost $100 I couldn't be bothered not using it.
I clean mine every 6 months or so depending what kinda driving I'm doing.
Also got a can of CRC AFM cleaner.
I chuck some of that on the afm when I do the clean and then again another few days later since there will prob be a little bit of excess oil coming off the filter.
Seems to be fine, Well haven't had any problems since anyway.
