Heavy duty STI shocks...?
Hey guys, I bought these shocks off Trademe. Just drove up to AKL to collect them on Sat.
What model do these shocks come in or are they optional...? I've never seen shocks so thick, they're roughly 40mm thick (will confirm with a vernier tomorrow)! Wander if the threaded rod welded to the top is standard or if they've been modified... ???
I was just wandering if anyone has these fitted, whats the ride like...? Oh and does anyone know where I can get a set of bump stops...? :-\
Guest loren
My standard STi shocks are 40mm or possibly more... my ohlins are 50mm and don't look that much bigger.
BTW, they are inverted shocks... possibly you haven't seen inverted ones before???
loren - Ay... I'm from Africa so these things are new to me... :D ;D Thanks by the way. Now I won't sound like a newbie in front of my mechanic tomo... :D
boostin - Thanks mate, appreciate you letting me know that. So I can just throw a set of springs (rubber bushes etc...) on and bolt the top hats straight on...? I've just taken an old set of shocks apart to see. Seems the only parts I need now are the rubber bushes at the bottom of the springs as my old shocks are different. Nothing major, I'll see what I can find tomo...
i have a set of these in my garage, they are V7 (STI Model) onwards.. I'm going to try and fit then into my Old school 90 RS. Some people say they will fit other not..
But they are def V7 (sti) or higher shocks
I fitted these shocks yesterday and I ran into a couple of small problems, nothing serious...
The front brake line brackets do not fit... I'm guessing because my set are Version 7 shocks... ??? I had to cable tie them in temporarily. I will be making brackets up today so I can bolt them in place...
The rears were pretty hard to fit - seemed like they were too long... ??? I managed to get them in, but my car now site 3 fingers off the tires! ha ha... :D
I'm ordering a set of Tein lowering springs today. Hopefully they sit low enough to look good as well as handle well... After cleaning my hub carriers for a while I noticed a bit of blue... Wonder if this is normal...? Guess they must be.
You will find that the car will sit higher in the rear using those shocks due to the different desgin of them
v7 onwards the rear shock are longer than the rest. But overall they should make a nicer ride and more stable in corncers
Lowering springs would be a good idea ;D
