engine mounts
wildturkey
square. the reason for this being better is they have this bit of metal which will only allow the mount to only move a bit if its broken, vs round which when break just end up being two bits of rubber - excess movement which cause stuff like front diffs to break (as i found out h hard way)
and yes both will fit.
Round are fluid-filled, square are solid rubber. The square ones break a lot less too. It's hip to be square.
Also turbo and N/A are different. I put some square N/A mounts in matts GTB since i had them lying round and both his round ones had died.
Yeah, the N/A ones are smaller, and no where near as stiff, so apparently the engines all over the fucking place!
 keltik said:
Ive got 2 here joe if you need them. Got them off tony but they wouldnt fit my motor
hey cheers for that bro..........i already scored sum off TM and I fitted them up today. Got the job done and learnt a lot in the process..........check out how fucked that passenger mount was. as soon as I jacked it up it just dropped away from the top half. I think its been like that for quite some time. The drivers side one was ok.
prick of a job..........don't wana do that again in a hurry.
I would recommend taking the radiator out next time because the extractors started to hit the fans as we raised the engine. Luckily it didn't limit the height we needed. I would also recommend taking off the brace that sits under the top mount.........I didn't take mine off strait away but when I did it made things a little easier. Pretty tight space to work in especially the drivers side but a little perseverence and I got the damn things out. I put rex ones back in they are solid rubber square ones.
quite a noticeable difference in reduction of engine vibration
brake007.jpg?t=1273908907
 Scoobydoo said:
The brace that sits under the top mount, didn't we tell you on Thursday that you would have to take that off?
Anyway, good stuff. Did you take notes / pics of what you did for future (anyone else's) reference?
yeah u did tell me ;D................but then someone else who has actually changed their own mounts on a BC5 told me they didn't need to take theirs off so I didn't........at first.
nah, couldn't be arsed taking pics but happy to talk others thru it
