Ventilation Control Stuck
Firenza
Hey, I got into my WRX today and as it was a bit warm in the car, I moved my control to direct air from the demist settin I had had it on, to the one that make it direct it through the heater vents...
NO DICE!
After much getting hot and bothered I noticed that the air was still coming though the windscreen vent. I can change the temperature normally, and I can change the fan speed, just not where it comes out.
I can hear a buzz from near the firewall when I select different positions on the dial, (like its trying to move the selector, and its always made a noise) but there is no change.
Where is the part that deflects airflow, and how is it controlled by the car. Also, how would I check whats at fault?
Chur
Pete
Guest lan_killa
Ive had a similar issue with my V1 WRX... have a look in the drivers side footwell at the side of the air box, you will see a mechanism on the side of it, see if that moves when you turn the dial... or give it a little nudge while turning the dial.
I havnt fixed mine yet, I pulled mine apart and set it to center vents. But I think the issue with them is they jam on the demist setting when your doing a bit of spirited driving due to all the linkages getting worn and the grease on them dissapearing over the years
Just apply some grease and "bobs ya aunty in drag"
