Fuel injectors
Ok Im a bit confused about injectors
Say you have a set of 200cc injectors and a set of 440cc injectors
The 200cc injectors are running a 40% and the 440cc injectors are running at 40%
The 440cc injectors would be putting out more fuel?
Guest boostcut
in a very broad answer, yes.
have a search on the net for some flow rate charts.
it will explain everything.
 kamineko said:
have you read "Useful guide for injectors" about 5 posts down from this post?
Yes but thats about how much HP per injector would support
well i think you answer your own question
if a 100cc injector is open 100% of the time you will have... well lets say 100 cubic centimeters of fuel flowed per minute, at a certain constant fuel pressure.
half the duty cycle, half the fuel flowed
double the injector size, double the fuel flowed
increase the fuel pressure, increase the flow - however the spray pattern may change
this is a simple approximation but you get the idea?
Which is also why you have to change your ECU when you change injectors.
I've seen a few people stick yellows in a grey top car and report overfueling. DERP, i wonder why. The ECU will be telling the injector x duty cycle, and the injector will do exactly that, but will be dumping more fuel than the old injectors.
So yellow injectors should be fine with a chipped ecu?
 Koom said:
And its programmed for .........cc injectors??
Was out of a car running 440cc injectors but in mine I still have grey injectors
 Koom said:
Is it out of a TT Legacy??
ECU's don't work if you just randomly swap them between different models aye.....
na it was out of 1991 rs then I put it in my 1992 rs
