Manual It (Question)
Divine
I searched, couldn't find anything to answer my question.
Here is my story so far....
I currently have a non turbo VZ type R 1991 Legacy. This is FWD Manual.
I found a AUTO GT Legacy (4WD).
How hard would it be to either:
A: Move my manual gearbox + other shizz to the GT Legacy
B: Transplant the engine to the FWD Manual?
I know nothing about moving a Manual FWD Gearbox to a 4WD car, is it even possible?
I would prefer option A. VZ Type R is Facelift, GT Isn't
GT: http://www.trademe.co.nz/Browse/Listing.aspx?id=281639361
Guest the_return_of_the_jedi
and facelift doesnt matter much, the running gear is all the same however since yours is fwd you be better off finding a 4wd box and fixing the turbo car
I see, cheers. Fountain of knowledge you guys are :)
I assumed my gbox would handle it because I was told the VZ Type R had all the turbo parts minus the turbo. (The turbo body kit, brakes, block ect)
vz-r engine is ej20d.. 2.0 non turbo
u could swap engine but u need engine, turbo, gearbox, loom, afm,ecu, fuel pump, rear diff, etc etc etc
I know a GT DOBC that's quite happily ASSPLODED a non-turbo gearbox from a newer Impreza. It weren't pretty! :o
Best option would be to put an STi or GTB gearbox (and matching diff) into a GT Legacy...this combo is brilliant. Drunkenmonkey and CodeMatt here on the forums have both done it to their GT Legacy wagons to great effect :) I will be doing exactly this too.
The VZ-R is a nifty little car but the motor and gearbox belong in it, not a turbo car. It's a bit of a nightmare switching between the two as there's a few differences between turbo and non-turbo. The 'GT without the turbo', 'WRX without a turbo' N/A thing is sadly not literal. There are wiring, trim, and major drivetrain differences that work to make your head explode. Had a bit of experience with this too... my second GT wagon came with a VZ engine in it!! :o Bought the shell without, as an N/A motor in that heavy ol thing is just....wtf. They had swapped out A LOT.
This is precisely why I am keeping 'the Mighty N/A' specifically that, and not turning it into a wannabe STi. :)
Yep, 1st gen boxes in short are just waiting to be exploded. Autos are just as bad with power...S2 exploded a nice one, Frankie decided to grenade one, Leonidas was obviously bought with a grenaded box... CodeMatt's box was blown too AFAIK.
Moral of the story: put a more modern box into your 1st gen :) It is worth the effort!
