**Help** need to know -> 2004 Outback
 funkytown said:
the NZ new outbacks or legacys don't have backlight gauge clusters - can these be back lit?
Anything else in the NZ new car i should note over a JDM import?
Really? I never noticed!!
If you swap the gauge cluster and the vehicle has a factory immobiliser, then you have to replace the keys too. The key code is stored in the cluster, the body control ECU (Integrated Unit) and the engine ECU. If any of those 3 is replaced, the keys must also be replaced.
Odo is stored in both, and they're never quite the same either. I know what you mean about the backlighting, i clicked last night. You want the one that blacks out when the ignition is off.
yer so - nah.. haha can you get one that is like that? ::)
