ecu upgrade
danz-rs
Guest boostin
Plenty of chips available for these too. I got my GT chipped by Dynamic Race. Raised rev limit, removes boost and speed cuts, raised boost pressure, "improved" ignition and fuel maps, and mine runs the bigger yellow injectors too.
Guest boostin
Either or. I got an RS-R ECU and chipped that, so I can always go back to standard with my old ECU.
Guest boostin
 danz-rs']
would i notice a significany difference???
You may do, but as we don't know the specs of your setup currently its hard to say.
[quote name='wildturkey said:
around $8 hundy
Oooh, a bit more than I was thinking!! :o
 boostin']
b]around $8 hundy[/b]
for that price youve got 1 foot in the link door :D might aswell save a lil' longer ;)
what sorta mods you got??
 kamineko']
[quote name='smokn4 said:
yours is a 4 plug,
i got a V2 RA ecu also for sale, itl plug straight in ;)
check it out the link ;D
url=http://www.clubsub.org.nz/forum/index.php/topic,9437.0.html]http://www.clubsub.org.nz/forum/index.php/topic,9437.0.html[/url]
that should be a Z5 ecu?
the sticker on it say's w6 i think...i got it when i got my ra manifold and the guy reknd the ecu and manifold come out of the same car, a v2 ra??? so was the prick lying?
the manifold does have the 5th injector
i looked it up a while ago and cant even remember what it i found out about it...
anyway a quick search on google or will sort it :D...might have a look later on its abit late ;D
got this from JDMVIP.COM:
U8, 2C - 1993/1994 WRX – TDO5-11.47PSI (0.8BAR) TO REDLINE -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
W6 - 1993 WRX RA – TDO5- 11.47PSI (0.8BAR) -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
W9 - 1994 WRX RA - 11.47PSI (0.8BAR) -FUELCUT 14.5PSI (1BAR) - 240PS (237BHP)
SA (STI CHIPPED) - VER1 STI (SEDAN AND WAGON)- 14.94PSI
SB (STI CHIPPED) - VER1 STI-RA - 13.64PSI
SC (STI CHIPPED) – SAME AS Z4 - VER2 STI WAGON - -12.7PSI (0.9BAR), DROPPING TO 11.7PSI (0.8BAR) @ 6600RPM
FUEL CUT 15.65PSI (1.08BAR)-260PS (256BHP) - 7250RPM
Z4 - 1995/1996 WRX – SAME AS SC- 12.7PSI (0.9BAR), DROPPING TO 11.7PSI (0.8BAR) @ 6600RPM
- FUEL CUT 15.65PSI (1.08BAR) - 260PS (256 BHP) – 7250RPM
Z5 - 1995/1996 WRX-RA - 12.57PSI
6K - VER2 STI SEDAN – SAME AS PRODRIVE-TDO5- 13.33PSI (0.92BAR) BUT PEAKS TO 13.6PSI (0.94BAR) @ 5600RPM, THEN DROPS TO 12.71PSI (0.87BAR) @ 6600RPM- FUEL CUT 15.65PSI (1.07BAR)-7500RPM-380CC
7K - VER2 STI-RA - 13.17PSI(0.9BAR) BUT PEAKS TO 13.64PSI (0.94BAR) @ 5800RPM- FUEL CUT 15.96PSI (1.1BAR)-
PRODRIVE UK ECU (PRODRIVE CHIPPED) – SAME AS 6K – 13.33PSI (0.92BAR) BUT PEAKS TO 13.6PSI (0.94BAR) @ 5600RPM, THEN DROPS TO 12.71PSI (0.87BAR) @ 6600RPM- FUEL CUT 15.65PSI (1.07BAR)-7500RPM-380CC
1C, 3B, V9, V5 , V9, 4B, ALL(?TBC) WRX WAGONS - 10.55PSI (0.7BAR) DROPPING TO 6.84PSI (0.5BAR) STARTS TO DROP @ 5000RPM – FUEL CUT 13.79PSI (0.95BAR) -
V7, 7D, 6D - 1993 TO 1996 UK/EURO - 11.4PSI (0.8BAR), DROPPING TO 9.4PSI (0.65BAR) @ 6600RPM – BOOST CUT 14.87PSI (1BAR)-
oh yea thats a wrx-ra, not that much of an upgrade really.
7k is what you want for a better upgrade though, used to run one in my v2 wrx, made a huge difference. the most aggressive 4-plug factory ecu.
that 7k ecu i had was from kaminekos car actually ;)
