4 Pot Brakes
Essentially I am after some info like dimensions, bolt distances/bolt pattern(between ea), etc
Searched but not any concrete info
There used to be a thread from before forum meltdown (even possibly two meltdowns ago) where the was info on what 4 pot brakes from what brand car fitted Subaru WRX/GTB/etc
From memory I believe that Nissan Skyline (R32/R33) ones fit, but I vaguely remember something about Toyota Prado ones fitting too...
I thought I copy n pasted this thread, but nooooo did not... (reason I ask is I have been offered some for a Prado)
Can anyone supply this info (and if you are, or a mate is in the position to measure the bolt pattern then that would be great!)
Edit: I believe its the Sumitomo brake calipers info...
bolts are the same size and in the same place as the 'caliper holder' bolts are on the 2 pot setup (ie the bolts that attach the caliper holder to the hub, not the bolts that hold the 2 pot caliper to the caliper holder).
Ergo, if you already have the 2 pot setup, you can just measure those that you already have.
As for the dimensions of the calipers themselves, don't have that information lying around and it's dark outside
hahaha all good, Im currently in Brisbane, car is in Whangerei... hence the measuring Q
From memory the Subaru bolt spacing is 155mm and alot of the Nissan ones are ~100mm. I remember the thread and there being mention of a specific Nissan that had 155mm spacing though? Rx7's also use similar calipers but not sure what the spacing is on those. Just add an adapter and run 330mm rotors ;)
