random hose
leggyfreak
Well that pipe isnt connected to anything else, it just goes straight into the bottom of the air con evaporator. So either youve used the air-con without knowing it or your passenger footwell is full of water and you havnt noticed.
The a/c kicks on when you put the blower onto the windscreen demist setting.
When you cool air, it shrinks in size, and so holds less water vapor. Cool a parcel of air, and it's relative humidity will increase, to the point where it'll start to condensate on things (100% humidity). Basicall, when you use the aircon, it causes condensation, and that's the little drain to get rid of that condensation... The ammount of water it pisses out depends on the humidity of the day.
