Noisey Belt
Todd
So got up this morning and started my car (2005 BP Legacy non turbo) and it let out an all mighty screech like a fan belt and lasted a while 5 sec maybe - pretty embarrassing, also when backing out of drive afterwards it was very hard to turn - felt like there was no power steering. Can anyone help with this problem?
Guest boostin
It will be your power steer/alternator belt. If the grooves are all shiny then the belt is stuffed. They're real easy to change if you want to DIY.
  • 2 months later...
 Koom said:
Have you tried tightening the tensioners on the two belts at the front of the motor? or checking that the belts aren't about to crumble and fall off?
Noob question, but how exactly do you tighten the tensioners cos my legacy ps belt/tensioners are squealing like a stuck pig.
cheers ;D
