DCCD light flashing error ver4 sti type r
Guest SPANKU
Guest SPANKU
something is up with my DCCD gearbox, the bottom green light keeps flashing like its in a Limp mode, anyone know anything about this?
seems like my whole car is on a limp mode even running at 8psi atm
If its V2-4 (the only ones i know anything about), The only thing that can trip a DCCD error is having the DCCD coil unplugged or broken or the thumbwheel unplugged or broken
Guest SPANKU
yeah its mostly the plugs? because that other night it was ok then it flash again and then went ok, then its now flashing all the time.
time for a 6speed gearbox?
Guest SPANKU
 GC8E2DD said:
caspros might be interested in your five speed if you're seriously considering a six San
yeah im selling the whole kit, including the R180 diff, hubs, looms, and speedo cluster ( i got a ver 2 and a 4 ones )
Guest SPANKU
ok i just been reading on another forum its got something to do with my sttering colums, as its not stright! i will try to strighten it later on. all this because my steering wheel isnt stright!
something got to do with steering angle sensor
Guest SPANKU
 kamineko']
[quote name='SPANKU said:
hmmm been reading some forums, might be a fuse?
yeah or an iffy relay
the relay seems to be ok i can hear clicking
 SPANKU']
this will only apply to bugeye+ models with auto-DCCD where the abs works together with the DCCD with G sensors etc.
your system is a LOT simpler - Dial position = diff setting.
sure thats not the fuel relay?
90% sure its going to be the connection between the dccd brain and the diff. it looks for the resistance of the dccd coil at turn on
so it will either be a loose connection, worn wire, or a damaged coil (seems unlikely)
check the connections by the clutch fork, and the connections on the gearbox by the centre diff. the one going into the square top plate is for the DCCD coil
your diff will stay in open or 'free' mode while there is an error so its safe to drive around. you just wont be able to wind it up.
Yeah no auto mode in your DCCD so its dead simple. Theres only about 3 components that could break down. Thumb wheel, Coil, Relay....or even the DCCD controller unit.
I dont know where any of those parts are in the stock locations. Im pretty sure theres a fuse on the high current power wire to the DCCD controller - if that fuse blows, maybe youd get a code? Im not sure.
Guest SPANKU
just been reading another forum... again our dccd is fully manual unlike the ver8 sti ones.
so chances are its the coil that died on it? will see about it later on.
but i would so love to drive this guy in a ver2 sti-ra dccd wrx
Guest SPANKU
wouldnt know how to get a code for it. waiting for itchiban to get back to us if he knows anything about it
Well theres only 3 things to check. Grab a wiring diagram and check to make sure all of the grounds are correct, the thumb wheel is still hooked up and you get a closed circuit across the DCCD coil wires. If all of that passes, the problem must lie with the DCCD relay
Guest SPANKU
 GC8E2DD said:
Relay is on on the passenger side under the glove box against the door jam.
yeah i can hear it clicking. i will wait til i get my spare loom back from Funky, the relay and everything is still there
