2001 V7 wrx sti wiring diagram
vr4ex
I'd say it would run fairly easily. Fitting the loom is gonna be the bastard bit. You'll need to separate out the engine ECU wiring from the rest, with both looms.
Im not so worried about that bit . The bit that concerns me is things like getting the rev counter, abs and speedo etc to work correctly. i realise that the speedo is easy as its cable operated on the legacy but what sort of input does the v7 ecu require and where will i get it from etc.
Pull both looms out, lay them side by side, and strip the engine harness out of both.
Where wires go off to other connectors, mark them and swap it to the other harness. Big job.
