Legacy B4 Can't erase OBD Fault code 61, 62, 65, 67
Hi all :)
I've recently had a problem with my alternator (the car started to die when I was on the motorway.. barely managed to get the car to a safe place) and changed the alternator. Seems like the battery was flat and the alternator was working flat out to charge the battery! Alternator was getting really really hot and the output voltage was 13.2 at first when I wasn't running anything other than the essentials (the flat battery was 550CCA Century brand).. anyways now after couple of hours of idling the voltage is showing 13.9v even though it drops to 13.2 when I have headlights (xenons) and fog lights on... sounds ok, right?
The problem is, just before the car started to die, CEL came on and when I checked the code (by connecting green and black plug) after changing the alternator the code was 61, 62, 65, and 67. I just assumed this was triggered because there wasn't enough juice at the time and could've screwed up the signals.. but after changing the alternator and charging the battery a bit, the CEL light is still on! I can't seem to erase the code by driving above 11KM/h with the plugs connected! Does this mean the solenoids are actually damaged and needs replacing?????
Thanks in advance :)
Diag check is BLACK plugs ONLY
Clear memory Black together and green together then drive over 11Km/h
When the plug that goes into the black box mount on the drivers side strut tower
That many unclearable codes MUST be linked
See this before with black box disconnected
61 Inhalation valve solenoid
62 Exhaust valve solenoid (vacuum)
65 Differential pressure sensor
67 Exhaust valve solenoid (+ve pressure)
yup
 JoKer']
yup
Thanks for the replies :)
Hm.. really?? 3 solenoids, 1 sensor and a alternator at once??
hm.. also I do have ZS Sequential controller and I didn't have it connected at the time (after replacing the alternator) and while I was driving I wasn't giving any boost as well.. maybe I should?
 stevolution']
yup
Did you check the black box of doom? Couold be a simple vacum hose not hooked up.
Also, I've had two of those codes when the bullet connectors for my ZS seq. Controller shorted out. How do you have it 'disconnected'?
 RSB']
yup
hm.. what is the black box of doom? I had the controller "disconnected" by just disconnecting the plug between the short controller cable and the loom that connects to the ECU
LOL just found out wat "the black box of doom" is... I'll check that also later when I get home from work...
:) cheers
Re-check your ZS wiring, you get all sorts of codes when that's wired wrong. Be pedantic about it.
If that's not it, i have a stack of solenoids left over from the conversion should one be broken. They're from a BG though.
Ok thanks :) I'll double check the wiring and make sure nothing is shorted.
Hey guys, thanks for all ur help~
LOL it was the zerosports sequential controller being disconnected... I should've known as some of the wires hacked up would be open circuit without the controller :)
    574.7k
