1999 v5/6 STI ECU problems
mr_people
 gazzy2000 said:
If not i.e. its only 10 PSI, i would wire in a LED test light across the boost solenoid and into the cabin and watch to see if it flashes i.e. when its flashing the boost noid IS being cycled by the ECU.
If it is flashing you have other boost issues causing 10 PSI limitations and if the LED isnt flashing its more than likely in safe mode due to other issues i.e. one being detonation (this can also be a crook knock sensor) and so on and so forth ;D
Ah, am I reading that right? Theres two IS. Which is the correct wun :-\
 Jambun']
[quote name='gazzy2000 said:
If not i.e. its only 10 PSI, i would wire in a LED test light across the boost solenoid and into the cabin and watch to see if it flashes i.e. when b]its flashing the boost noid IS being cycled by the ECU.[/b]
yea, you read right, there are two 'is', the second one would read better if i had of wrote "if it is indeed flashing you have other boost issues....."
does that make better sense?
EDIT: seeing the LED flash basically proves there is voltage getting to the boost noid (while you are driving etc) and of course that is a good thing as it means the ECU is doing its thing in the boost control department.
If it is indeed flashing but you still have 8-10 PSI there is another problem.....
