2 Port or 3 Port Boost Control Solenoid
Leighos
Which one should a V3 STi have?
I'm just tidying up a few things on my BD5 RS after a lengthy single turbo conversion, and I'm getting rid of the old boost tap in favour of the factory boost control system, for reliability and safety reasons.
I'm running a 6S ECU, a TD05H 'Big' 16G (with a wastegate actuator from a TD04L) and a 3 port wastegate solenoid from an early WRX. Its a bit of a mix I know, but it runs well and comes on boost surprisingly fast, the only issue I have is that I'm only getting about .8 Bar of boost.
I'm running a factory forged piston V2 STi block so I'd like to be seeing at least 1 Bar, should I ditch the 3 port for a 2 port with restrictor pill?
I have heard the 3 port solenoids are better and less prone to boost spiking because of their 'interrupt' design rather than a 'bleed' type.
What opinions do you guys have?
