Dashboard swap v1...v5/6 questions
XSCIV1
Hey guys,
Just wondering if anyone knows if the newer wrx's like v5 etc still run a speedo cable type system or is it electronic with a speedo drive?
Im thinking of doing the newer dash swap in my car & need to know if it can still run the cable with the newer digital odometer etc
as for wiring I wont be running all the heaters/fans etc anyway so thats not a biggie
Thanks,
 XSCIV1 said:
so in order the run the newer dash, what would need to be changed?
The speedo drive on your gear box plus the wiring from there to your dash
Sorry I dont know if there are any other little bits as well
Good luck :)
Sweet well it looks easy enough to swap that over & wire it up to the cluster, I am assuming there would be wiring that goes to the ecu aswell ? I am running a apexi RSM aswell which may come into it aswell(not hooked up yet)
