*Bearings* Anyone used these...
subaru-mania
depends on how you build your engine.
My older engines I use to build/have built, use to have "hard" type bearings. Thin, exotic muilt metal "whitemetal"
While these were meant to last longer, if you ever had oil press problem (oil surge, oil leak, oil pump problem etc ) the bearing shells would instead damage your crank/conrods to point they be useless in a very short amount of time.
Now we use a "soft" bearing. (i think its mainly a Ali type alloy) Now if we ever have a major oil press problem, we can normaly shut the engine down in time and have a better chance of saving the rods/crank. (which is about close to $8k worth for rods and crank)
Theres alot of trial and error with builds like these. I think theres only 1 or 2 that might have experince with multi subaru engine development on this forum. Its not just buy some forged pistons/rods and slap them in a closed-deck block and you have 400kw....
