hit boost and car stops goin
leggyfreak
Got a boost gauge in the car (what are you boosting)? Have you been playing with vacuum lines? Got a boost tap?
Sounds like you're hitting boost cut, i would be very gentle on the car till you figure out what's causing it, and solve the issue.
If your speedo doesn't work, then after sometime (a few hard boosts) then the car will go into limp mode, it will not necessarily put up a code.
Thats certainly the issue. Get that fixed and you'll be set.
