Speaker spacer installation - need help
chaminda
I'm installing 6.5 inch pioneer speakers with tweeter in front. I've already bought these spacers (6.5inch)
http://www.trademe.co.nz/Browse/Listing.aspx?id=348535494
Not to sound stupid (which I am) but which way around do i install them? I haven't taken by door panels down yet but planning on starting the project on saturday. Any help on how to install them would be great!!
thanks
Hey, well it doesnt relly matter what way you instal the speaker itself normaly, as long as you install the cover/grill the right way so the logos are at top/bottom , but for the speaker itself as a rule just keep the wire terminals at the bottom and you shouldn't have any issues :P
You may not need spacers, the speakers should fit inside the black factory plastic spacers. The only thing you will probably need to do is hack the "shield" part off the back as the speaker magnet may be too deep for it. That will certainly be the easiest thing to do, if you can. Subaru utilise a proprietary 'triangle-3-screw' system for holding the spacers in place, so a standard round one won't fit.
The only problem you may encounter is once the speaker is screwed into the spacer, wind the window down to check if it hits the speaker magnet. if it does, then you will need to make a custom-shaped spacer out of MDF - those round ones won't work. Trace the shape of the black plastic spacer onto 18mm MDF, cut that out, and use that as the spacer.
That will work. You won't be using the grills though, they won't fit behind the door cards.
If that is beyond you, then take it in to a car audio shop near you and they will be able to do it.
