wrx twisted turbo set up?
wrxboy
Hi, im thinking about upgrading to a twisted turbo set up in my wrx, what is peoples opionion on twisted turbo setups??
What do you need to upgrade? apart from the fuel pump. do you have to upgrade the injectors? or can you stay on the factory 440cc ones?
Has anyone had one and had endless problems with it?
Id really apricieate the help.
theres a nice twisted setup on TM atm, to get a tune, you need some sorta After market chip so you'd need to get someone to fit an tune it wouldn't be cheap but would run 10x better
you also wana do split fuel rails mod an goto a different injector
i wonder bother with it man.you may aswell get yourslef a new turbo.a tiwisted setup will cost you alot most of those setups are for front mounts kits.the you need all the parts for the twisted setup.get yourself a vf23 22 or something and a link and youl have plenty of power
