LSD Identification
WRXONP
ive just done alot of research on this forum and other forums plus google about how to identify the LSDs apart from each other...
heres some pics of my LSD / differential
i havent seen any sound identification so far...everyone seems to be guessing...
one guys says this could be a quife LSD and one guy said it could be a AP SURTRAC LSD??
can anyone confirm please? it certainly doesnt look like a viscus...
so in saying that i just got a 1litre bottle of 80w90 i think it is and thats going to be no good if its mechanical ... so anyone want the oil LOL
To me it doesnt look like a mechanical plate diff. The fact that its a full sealed unit (as far as I can tell from the pics) suggests its a viscous. In fact in looks nearly identical to a V7 STI suretrac that I had laying around...
Can the centre be pulled apart at all? Are there any holes in the outer casing which you can see into the centre?
  • 2 months later...
the people who installed my diff thought it was viscous . they put normal oil in . it had little lsd action. removed and cleaned and re fitted with proper lsd oil and turning it you could feel it doing its thing and working in . . . now its real tight lsd action . . its a sure track cam follower type lsd
remove Rear diff and drain oil then the back cover comes off 6 or 8 bolts can't quite remember. you'll see it what type it is . i removed my crown Wheel lsd assembly . you just remote side plates where the cvs go in then assembly comes out. but there are shims behind the plates which set the back lash . remember to keep these on the same side they were removed from or you will fark your dif
Thanks for the help, once out what should i be looking out for? Not sure how to tell between or even if its lsd or not lol
