Wobbling Crankshaft pulley
Our old runabout seems to now have a wobbling Crankshaft pulley when looking at the front of the engine with it running.
Should I be concerned? ???
pull it off and check the crank / pulley and key
Not uncommon to damage the crank if the crank bolt has been left loose at some stage
Cross ya fingers, as normally it means fubar time
:( reminds me of when you pulled mine off Rick... keyway was like a wedge shape = fubar'ed
if it just needs a new key etc and hasn't damaged much would it be a cheap fix?
Its only been doing it for a week
however contray to what was said above it could be hte pulley itself wobbly.
I had one i just fixed on my brothers pulsar where the "inner" part of the pully is joined to the "outer" part by a rubber or something of some sort. This had perished or whatever so the outside was seperate to the inside casuing it to wobble and not spin properly..
COULD just be a fucked pulley but as said pull the pulley off youl soon know.
 subtek said:
weld the crank pully to the crank that ill fix it
Indeed it will, and please please never touch a car of mine EVER ! :)
Well if you weld the inner part of the crank pulley to the crank and the harmonic balancer is whats creating the wobble . . . Then welding it wont fix it . . . . . Plus the heat of the weld would melt the dampner . . Among other things .. You would never be able to change cam belt or remove crank for rebuild . . . . He you can see the crank pulley bolt . . . Is the bolt wobbling ? Or running true ? If the bolts running true and the outer of the pulley is wobbling then id say the dampner is toast . . . If inner and outer is wobbling its to do with the key way
