EJ20 front main oil seal
I've got an oil leak comming from the front of my ej20 and i suspect its the front main oil seal. I've never done one of these on a wrx b4, can it be done just be taking off the crank pully and cam belt cover like most other engines?
 DRFVDR']
[quote name='Stoffa said:
you should do your cam seals while your in there too
+4 :)
also cambelt/tensioners/idlers oil pump seals and maybe a waterpump
+5
and crank seal... if you miss it and it goes poo poo.. you'll take it all off again..
There is an O'ring behind the oil pump - replace that also
And while the pump is off check the screws holding the rear pump cover on
they come loose and can cause the front seal to be pushed out
