Oxygen sensor issues - hesitation in closed loop
Yea at idle it just sits around the 14.7 mark on the wideband, driving at 100km/h cruising on light throttle for 10-15mins you can see it going into open loop(afrs richen up into 13.5-14.1 range) with a bit of load(ie small hills) then on the flat the afr's drop back to anywhere from 14.6-14.9. Cruising at anything over 3500rpm seems to push it back to open loop as well. Other than that no massive corrections can be seen, no wild swinging of the afr's as running with the narrowband controlling it.
  • Replies 52
