99ecu into a 97
is this able to be done.only reason i ask these ecu's are reflashable.there for i wont need a link.
not sure if you can wire it in or not?has any one done this before?
 sti8u said:
negative, thats version1/2 generation 4plug. '99 is 4socket,3plug. see this post for a pic http://www.clubsub.org.nz/forum/index.php/topic,9493.0.html
the answer to OP question is i can't see why not. but you'll need to figure out the wiring and earthing yourself, i havn't come across any info on that swap yet.
you might need to use the v5/6 idle control and AFM though. however i suppose you could tune around it
