axle length
Guest loren
Guest loren
One last problem fitting my new rear diff... while putting the inner CVs back on after machining,
I noticed different markings on the left and right axles, and that one axle is about 7mm longer than
the other.
Both have two 5mm wide grooves about 5mm apart close to the inner CV, but the longer one also has a
wider groove.
http://picasaweb.google.com/loren.brookes/RearAxles210409711PM
Anyone know which is left and which is right?
Guest loren
These are my old axles, I just didn't pay attention when I took them out because I thought
they were the same >:(
I took the inner CVs off to have new circlip grooves machined, now I need to figure out
which axle should be 7mm longer...
If I can't figure it out, I'll put the diff back on the car and measure the distance to each
hub, hopefully there will be a small difference, if not, maybe it doesn't matter.
Guest loren
That was easy to solve... the diff is not mounted dead center in the rear sub frame, it is offset to the left.
I wonder if that means the driveshaft is on and angle from the gearbox or if the gearbox and engine are
offset from the center as well?
Guest loren
No, the diff is symetrical, the holes in the subframe that the two front bolts sticking out of the diff go into, are not in centered.
Take a look at yours. oh wait... that photo should shows the mount... is it symetrical? looks like it may not be exactly.
Guest loren
yeah, now I know which side needs the longer one... I was just asking because I didn't have time to look last night.
Guest loren
 Optical said:
do you have a counter balance on the side of the car with the shorter shaft?
counter balance on what? there's nothing I can think of... I can't think of a good reason for it being off center either,
unless the motor and gearbox are also off center and it's to counter balance the car when there is only the driver... but
that sounds like a long shot.
Guest loren
 Optical said:
nah im just talking sh1t now :)
you think that's sh1t? you should see some of the stuff Shale has been saying today :)
 Optical said:
what happened to your old axles?
I think only the old legacys had different length axles?
I know that if you were carrying out a say later V6 STI gearbox retrofit to your Gen 1 RS then you need the matching 4.44 rear diff as well as the drive axles to center the diff.
If you use an auto 4.44 your OE drive axles clip right in.
