WHAT THE F*** ARE THESE!
Guest 4wdftw
Guest 4wdftw
found these stuck to my magnetic gearbox sump plug.and no im not talkin bout my fingers! reason i asked is because im having to do a gearbox swap after losing 2nd gear
Is it difficult to find reverse gear? Have you or anyone that you know of slammed the gears from 1st to reverse?
The reason I ask is that they look like 2 of the 3 detents that allow you to select reverse gear.
[Don't ask me why I know :)]
thtd be the reason then.... pull it apart and put them back in and youl have a spare.... they are on the main shaft.. obviously 2nd gear shift hub.... search for a diagram bro
Guest 4wdftw
so these not being in there would make the clack clack clack noise?
why did they come out in the first place?
oh and there is drive in 2nd however i changed 1-3 after the noise. ( no i didnt drive around using 2nd gear when it was like that )
the shift ring/sleeve will be cruising around on the hub and bangin it im guessing.... did you change real fast before it happened? either that or the spring that holds tension on the back of them broke and they fell out the back.... hard to tell until the box is apart
Guest 4wdftw
that makes sense now. :)
nope just normal changing.
will pull the box out tomorrow and crack it open. will post pics.
you would be amazed at wat 1 grain of sand can do to an automatic trans then..... they arnt just two bits of metal.... they have a very specific job and without them look what happens
yeah maybe.... check that the springs etc are still in good cond etc.... maybe get a gearbox specialist to check....
Yip syncro detents for sure
I'd take a wild guess and say that the input shaft nut has come undone and these are from the 5th/rev syncro assembly
It is very possible that one of these (prob the missing one , there are three of them) has gone through the gear set
Guest 4wdftw
 funkytown said:
pictures! Lots of people want to see
yep! im gettin there! gotta get the damn box out first!
heres a tip! if your taking ya driveshaft out, replace the bolts with NEW ones! makes it much easier next time!
 4wdftw']
Did you get that bolt off...sorry i had to jit (didnt find a grinder tho!), back in Dunedin now, cars going mint....hope ya get it out and back in with no probs....
