Hks evc 4 issues
johnny5
Ok so installed the above boost controller runs ok on wastegate pressure on low boost of 9 lbs switch to high which is 18 lbs and no go. When its hits say 12 i hear a weird noise like when you squeeze a baloon at the end and let the air out. So i have tightened all lines as much as possible so it might rule out a leak but has anyone come across this at all hoping the solenoid is not fucked and i didnt buy a dud
 WRXONP said:
If solenoids f***ed u get either only stock boost know matter what duty cycle or u get no wastegate control
Cool yea i get stock boost on low but step it up to high then when it hit 12 it drops off and makes that fucked noise the other thing i didnt mention was im not running the vacuum filters yet as i cant make it into redline
Air leak bro
Check all hoses and intercooler y pipes
Basically all joints -
turbo outlet to red intercooler pipe
The y pipes Under intercooler
The Bov is sealed tight
The throttle joiner
Hopefully it's one of them
I have seen ppl have Bov not bolted properly to intercooler
Everything is tight i guessing its leaking somewhere only happened after a few days Was all good then it turned to custard jus wondering if the hoses aint closing brand new hoses to but purchased from supercheap but as i said its only past 12 lbs all of a sudden it jus starts dropping off to zero be good to get your opinion brad when you aint busy was even thinking bout returning to stock as its pissing me off
 WRXONP said:
I would come have a look but I'm stuck at hospital lol - if u leave the evc in there but just plumb the factory solenoid back up do u have Ur 21 psi back again without the sound ? If u do the problem is related to the evc
Will plumb back upto standard and let you know. Hope you get better soon bro
U got this fixed bro?
I'm in a similar boat lol
Had missing/surging issues and turned out to be faulty connectors to spark coils
Changed plugs while at it
Thanks to kingpin and jpar196 on that
Now have a boost leak as soon as u hit 9psi aaaagghhh!!
Hate issues
By the sounds of it, it's nothing to do with the boost controller.
If it is an air leak, if you have access to a compressor try pressurising the intake - block off the intake @ the AFM (a baked beans can is 3 inch haha) and crank 20psi in there.
If there is an air leak, that's how you'll find it in no time. It will bleed pressure off slowly (like 1psi a second) - anything more and start listening for a hiss.
The boost controller is going to either work fine, or it will either stick open (and give factory boost) or stick closed (and freeboost), what you're describing sounds like either a misfire (check the plugs, look for an extra black one) or an intake leak somewhere.
the car ran fine before he put the controller in - instead of farting around with a compressor just hook the standard solenoid back up how u had it before and see if its runs like it use to - if it does - work from there to get the evc working properly
How would a boost controller cause what sounds like a misfire or leak? Car fine on w/g pressure, hits 12psi starts farting around, sounds like misfire - he could be using a hole drilled in the wg line to raise boost or a $1000 EBC it still has the same result
