Wastegate Position????
STiNGR
 maserati mick said:
i run a vf28 and tsmart 35mm ewg 14.5psi spring and the internal flap never opens
was that when you just unplumbed the vac lines to the standard actuator? i put a 35mm tial on my type r with 7psi spring and ran a gfb boost tap, never spiked over 17psi, had same boost tap on my starlet and never spiked (maybe 0.3psi if that). found easiest and cheapest way to put on an ewg was to by legacy 250t headers and weld a flange by the up pipe as they are mild steel. worked well for me
 maserati mick said:
you wil have the td04l wrx with yellows correct??your factory internal will open at 14 you might need a sti actuator with the 16psi rating or just shut the internal flap via weld
Correct. But ditching the tdo4 soon.
 maserati mick']
/quote] actually the factory internals only hold 10 im sure
Well if thats true thats ratshit.
 STiNGR']
Are you talking about the factory "internals" as pistons etc or gate?
Well if thats true thats rats***.
