wrx engine into legacy gtb problems
Green Machine
Hello,
So I asked afew questions on here and did some research online and it seemed to come across that there wasnt much difference between v2 and v3 wrx engines in terms of wiring/sensors but I think the information I got was wrong.
So I have put a v2 wrx engine in my bg5? gtb 1996 legacy and am trying to get it to run using a v4 wrx ecu as I was told this would would but its turning over but not firing. I did what it said to do to my wiring in the single turbo legacy conversion thread as I figured that would be the same and the engine looms like almost identical with the same colour wires going out of the plugs.
How ever there are 2 extra wires that I have found so far from one of the plugs by the battery.
One is a brown wire and the other is red/green wire.
I think I traced the brown wire to the tps sensor which is a 4 wire but looking at my old loom it looks like the old tps is a 3 wire??? Would that mean I need to put a newer tps sensor on in order for the ecu to work as I would assume the wrx of the same year would be same tps as the gtb.
Also would I need to use the coilpacks on the plugs from the gtb to work with the v4 ecu or would the v2 coil packs work fine???
Is there anything else I may have missed?? Its annoying me as I just cant get it to start.
edit: Also is there anyway to check what error codes a car is throwing without plugging in a reader thingy? On the hondas I used to be able to jump 2 wires and it would flash each code on the dash. Do subarus have anything like this?
Cheers Haden
hmmm 96 gtb - likely closer to a version 3 wrx engine
how many ecu plugs did the legacy have? 3 = moreorless the V3 wrx setup and 4 = moreorless the V2 wrx setup
yes the TPS and AFM differ between V2 / V3
your basically doing a single turbo conversion, have a read up of those threads
