BE5 Factory Camber Adjustment
Jord
Had a laser wheel alignment done about 6 months ago as I started to notice inner tire wear on all four corners, I suspected the camber was probably out. After the wheel alignment I had a brief chat with the guy who did the alignment who said the rear toe-out was out but he sorted that out and would be good until the next alignment is due (20,000ks) I recently noticed the that the inner wear was getting worse, so I went through my paper work and found the printout from the alignment. Surprise, surprise they never adjusted the front or rear camber.... Do they not normally adjust the camber? Not sure why the camber would be so out in the first place?
 Jord said:
Factory Bilstiens + STi springs. About 20-30mm lower than factory.
So theres nothing I can do about the rear camber? :-\
-1.86 degrees on the left rear wont be helping with tire wear..
you could get the dremal out and make the rears adjustable . aftermarket coilovers like the d2's i have come slotted so that there's more adjustment .
not sure if its legal or not but i really dont see why . i had to do it to my gt to get it where i wanted.
 rex-leggy']
They use multilink rear Josh so cant slot it out :D
