who's that knocking...
smokn4
As said above check oil and oil filter for metal -
Got a oil pressure gauge ? As the tolerance on the big end increases the oil pressure will drop - run the big end so much the heads will eventually get no oil pressure as the oil will be going straight out the huge clearance in the big end
it's quite possible to feel a big end knocking through the clutch pedal - as the big end bolts the rod to the crank - with a large clearance on the big end bearing the knocking sound is the rod hitting the crank while changing direction ( up to down - down to up )
Think of impacting on the crank - the shock going through the flywheel to the clutch to the clutch fork - the more revs the harder the impact on ye crank
Sticking lifter is quite possible since u have lifter heads - but it would have done it on first start up - like also said above the screw driver stethoscope will tell u what u need to know - if your hearing it near the centre of the block where it splits its almost certainly beb
The other thing which can make the clutch fork take a knocking is crank walk - grab the front crank pulley and see of it has back and forth play (axial) - not radial (up and down)
