93-96 WRX Short Shift Install Help!
tmuff88
Hi guys
I have bought a short shifter for my WRX, it looks like this
But dispite my best effort so far, i cannot get the old one off!
Has anyone fit one for a early WRX?
Is there a trick to it? I was just pulling it...
Thanks for the help
Unbolt everything from your factory shifter the pull it all the way back towards the back of the and push it down like your trying to flatten it onto the transmission tunnel it should POP out. Spray some crc or grease in there and wiggle it if being stubborn.
I FOUND IT EASY TO GET OUT BY RESTING IT AGAINST THE SIDE OF THE BOX HALF WAY DOWN THE SHAFT AND LEAVERING IT THERE, THEN TO GET BACK IN DO UP THE BOLTS HALF WAY DOWN THE SHAFT AND LEAVER AGAINST THAT TO FORCE THE BALL BACK IN.
damn caps! im not writing that again...
