stepper motor gauge vs manual guage
speedfreak
hey guys,
looking at the later stages of my engine rebuilt at the moment, just looking for a guage set, what are your guys thoughts on gauges? stepper or manual?
are going in a rally car so need to take a bit of a beating
looking at the below set
http://www.trademe.co.nz/Browse/Listing.aspx?id=463074034
let me know your thoughts, suggestions and what you have had experience with
If going in a Race car, more so anything with alot of bumps and dust. Go Mech. (or gauges with electronic senders)
Gauges like Defi dont handle the bumps as well. (for road or nice smooth track they great)
Recommend Autometer Pro-comp liquid filled gauges.
Stepper motors are supposed to be more acurate.
That said it would probably depend on the make ie. you get what you pay for.
Autometer gauges are usualy quite well priced and or good quality. Dont get them mixed up with their cheap counterpart though.
I did a Cal test on my Defi gauge and it had a 1% error across its range. May not sound like much, but accurate is class less than 0.1% error.
But you get what you pay for...
 D-Style']
care to explain how you got the 1% error
how you read it and what the 1% was
did it read 99 degrees when something else said it was 100 ?
in which case the difference is like less than half the width of the needle ?
  • 3 weeks later...
In general yes, you put a given input in the meter and you read what the gauge says.
I did a 10 point Vac/Press and 5 point press only on a few different gauges a fair while back. (using a Beamex MC5 Calibrator)
Both my own Defi and a mates Trust gauges had some error in the readings ( 0.05% is a standard industral max error)
Also some Mechincal Gauges had error straight out of the box.
Also Mechincal gauges start to lose there accuracy after a few cycles.
While you may think 1% or even up to 10% out is no worry, If im paying $300 odd for a Defi gauge I want it to be spot on.
