Auto - Manual conversion
in all honesty the auto engines are de tuned with different injectors and airflow meter as a result they put out like 20 kws less also for the money youre going to spend on converting it you may aswell sell your legacy and get a factory manual one
 Schematica said:
Got the chance to buy a RS legacy manual gearbox, How hard and how long would it take to convert my 97 GT legacy from auto to manual? and what would the job intail
usually gearbox,speedo,diff, flywheel, starter, clutch and pedal + gearlever..interior plastic bit..2k job or thereabouts
 soopersubaru']
driveshaft as well depending on the links to the diff some knuckles are diffrent i did one of these on an auto gt legacy (ended up using a 2.2l outback driveshaft) replaced everything mentioned above just to get a wof again. not worth it unless u have the time to do it all yourself
