Full loom
Cost depends on whether or not you are replacing the connectors with flash ones (i.e. Deutsch) and recovering the whole lot or if he's just patching the needed bits into the existing?
Cost would vary from lots to heaps depending on how much he's charging hourly? But anything wiring related takes hours.
I just had a full engine loom made, from the ecu to every sensor, coil and injector.
My auto sparky spent just shy of 20 hours and i did the time consuming part working out all the pins for the ecu and the sensors. all with fresh plugs and using a link "a" loom.
Its pretty easy once you get you head around it. i just wanted it tidy so paid someone to do it.
theres a 5v system. a 12v system. cam and crank whick make their own voltage and the ecu basically just switches on the earths
