cvs slipping
gtb36
hi ppl, can cvs slip ??? its just when you take off hard and go around a round about very hard there a big noise from the back end and it seems to pull the back end in/down with a big bang bang noise not sure what it is
thanks for any help
 Koom said:
Nope. They'd be very broken if the outer could spin around the inner bit.
Weren't you asking about centre diffs elsewhere? Sounds like the diff is binding up. What state is the rear diff in?
yes been thinking center diff.. but when you turn left and right slow it dasnt make that noise same if i go around and around no noise and rear diff new not to long ago
 pl0x said:
yup id say it was center diff binding and worn rear diff bushes banging
yes been thinking center diff.. but when you turn left and right slow it dasnt make that noise same if i go around and around no noise and rear diff new not to long ago and new rear bushes as well..
Sounds to me like centre diff... Mates bg did the same thing. Only felt bound up and only in one direction.
His made the normal inside wheel skipping thing noise if you applied power when taking off or doing a tight turn
It was most noticible when you did a u turn on an intersection that had loose gravel.
