Hey guys,
Im looking to upgrade my 250t wagon swaybars for less body roll and stiffer ride and have a couple of questions.
1. What size are GTB bars?
2. Will the GTB bars fit straight in?
would have to check the fronts but pretty sure they will the rears definetly would
they are 19-20mm front and 20-21mm rear is I remember correctly my rsb was f 20mm r 21mm
its been awhile since I looked under a NA bg BUT my brothers bh 250t exhaust is different in the front end from the turbo varierty so you may have interference issues with the front bar, but only way to really find out is to get one and try it :)
Ok thanks guys
I measured my mates 98 gtb and front is 20mm and rear is 19mm so i will most likely be getting myself a pair as they are cheaper than aftermarket ( whiteline )
