hydraulic handbrake
has anyone had any experience with them? have done some searching and from what ive seen you can tee into the line going to the rear calipers and run that through the hydrolic system .
what i cant seam to find is that if you do that will the oem system still work as normal .... as in when the brake pedal is pressed the rears will still work .
i will still be retaining the factory cable driven setup but this would just be an extra for gymkhanas ect
