92 GT handbrake light on
92LEGESI
1992 GT legacy BC5
auto, just had engine changed but now handbrake light stays on even if its disengaged ? wont go into gear at all, the lights change though etc
- i have tried taking the sensor thing on the handbrake base but its all good, i even took it apart to disconnect and connect wires and still no go
just wanna ask here first if there's anything i should be checkin before i go pulling unnecessary things off etc
sweet
guy before me replaced the engine, it does make a sound like rocks in a bowl SOMETIMES other times it runs with no sound
- brake fluid level's good
- trans fluid's good
handbrake light just wont go off and let gearbox engage if im right... ???
I think when you put the torque converter in you haven't aligned it correctly so it's probably not running the oil pump so that would be causing the no drive as for the hand break my car does the same thing if you leave it on for abit don't worry about it the light should go off when driven for abit.
yeah and the sound your hearing " rocks in a bowl " it could also be the torque converter chewing / rubbing against the oil pump or the torque converter seal could be broken and rubbing against moving parts, from listening to your video the sound is coming from that area any way I think defiantly take the trans out and inspect it.
 AshtonC']
thanks man was def thinking it was auto box and sounds about that way too just was unsure as sound came and went
lol was juts gunna say " Auto RS?" but your working on a GT as stated in 1st post, aint nothing to do with a RS
Keep getting the two mixed up so i just call my wagon the GT and this the RS even though it aint :P
[quote name='Eight dollar said:
if convertor not lined up properly and engine installed it will smash the tranny oil pump and put metal thru box :(
remove cooler lines and run into a bucket - start engine and turn off within 2 sec
No oil = pump fubar or no oil in box
Cool will try this first and get back
if the torque converter isn't aligned properly it wont drive the oil pump which of course means you wont go any where and no oil will come out, just because the motor bolts up to the box doesn't mean you don't have any issues :D
