GF8 SAI Measurements
Hey all.. Does anyone know where i could get the factory measurements for a GF8's SAI (Steering Axis Inclination).
Looking to get my camber adjusted but would need factory SAI measurements before playing around with camber strut adjustment through bolt.
(Funky you will probably be able to help me on this)
Thanks all
Your SAI shouldn't change if you are just adjusting camber via a camber bolt on the strut clevis. It would change if you were moving the top of the strut inboard or outboard from the stock location via a top hat or other custom strut mount. The factory SAI will be available from pretty much any alignment shop that has the digital factory records by model. I can probably find it on an alignment sheet somewhere if you are stuck.
Yeah ive got adjustable suspension with pillow ball top hats which have adjustments for the SAI and our allignment shop said to start off by getting the SAI to factory adjustments before moving to strut clevis. He does not have a digital factory record so would you be able to find my factory SAI for me if possible?
1996 GF8 STI
The last alignment I had on the Impreza showed +14°40' as the factory measurement. It is a 98, and I would imagine the front end geo to be the same on all GCs/GFs - at least with the early alloy arms anyway. Someone else may know better.
