ECUFlash 2002 B4 - ROMs and Definitions
BlitznB4
So after a little help here.
I have a revD Blitzen in which I have pulled the ROM from the ECU via ECUflash.
I want to retard the base timing a little do get rid of a little det.
I am having trouble locating the definitions for my ROM, can anyone help here.
My ROM ID is A4SH701H, but if someone has another TT B4 legacy rom and definition I guess i could flash that to the ECU.
Is there any other solutions?
 chappell943 said:
Try over at ww.Romraider.com and they should be able to help, I've looked at a b4 rom before in RomRaider but it seemed to be missing alot of tables
Yeah will do, I can open the rom, but yeah its basically missing all the tables - so the definitions aren't complete.
Cant find them anywhere on the net, will post on romraider and openecu, but thought someone on here might have them or know where to get them.
 telemekas said:
Download Subaru Select Monitor (SSM) protocol.
Adjust timing up to +5 or -5 degrees
http://developer.berlios.de/projects/freessm/
Thanks, I will download this and have a look - the timing is just all i am looking to do at the moment, as there must be slight knock to retard timing and boost on 95, 98 is half an hour away :(
If anyone else out there knows where to get B4 definitions (XML files) for ecuflash or romraider as the definitions they provide are DTC only (diagnostic only defs) it would be awesome.
