Gazzys new ride - 89 Leone wagon Turbo
gazzy2000
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
Oh I seen that on trademe :)
They are a good car I been looking for one but don't have the cash,
I have a parts book and a crap load of parts if you need anything
There was a set of 15" leone rims on trade me last week these are nigh on impossible to find, it will be very very difficult to fit impreza rims to it , also getting any after market springs are impossible.
yea, i have owned two of them YEARS ago :)
will def keep u in mind for parts thanks
look forward to cheaper fuel bills as we might be moving into the country... to eat me alot of peaches
 94 Leone said:
If they have enough room for another 20mm drilled out of the centre each side, and then room for the lug holes.
It's possible, but unless you smoothed them off and repainted/powdercoated they'd look ugly.
yea right.. well i cud get the old holes smoothed and powder coating is dirt cheap (here any ways) so maybe thats a thought?
Yea I got those 15s, superlites, so stoked they look sick on the coupe compared to the 13s, hurt the wallet tho
 tim green']
/quote]Yea I got those 15s, superlites, so stoked they look sick on the coupe compared to the 13s, hurt the wallet tho
Oh you got them :) I bet they do look nice, so wanted them but oh well, at least they gone to a good home :)
Gazzy the fitting of the impreza rims will be a headache, best bet would be finding a set of XT6 hubs as they are already the right stud pattern AND fit the leone struts, failing that you can try to redrill the leone hubs BUT the difference in PCD will be the issue. I have thought about mixing and matching the later model drive flanges to the Leone hubs, only issue i could see is the brake rotors not lining up then having to make adapters for the calipers ( would fit some bigger brakes at the same time as the brakes aint to good when slowing from 200 Km/hr)
i am really looking forward to gutting the interior and steam cleaning the lot!!
will source all the small interior bits n bobs... replace and fix it all!
first thing will be radiator removed to be flushed professionally (like i always do) will do thermostat too.
Will tint windows aswell
will remove cat converter and fit a big bore too LOL
Hard to tell it is quite high so it may be stuck on the HIGH setting, but usually if it is the air controlled one then by now the bags are buggered and she would be sitting on its arse.if it is the hydraulic system then it may just be a fuse... I have a full hydraulic setup for one of these here, was thinking of putting it in the RX once i lower it so i can pump it back up for the extra clearance :)
you will have to get the big bore made as there is no off the shelf solutions for these and the turbo is different enough that a rs one doesnt fit ( I made my own )
